Activity › Forums › Adobe Premiere Pro › Export takes long time
  • Export takes long time
    Posted by Dorian Weber on August 6, 2012 at 2:59 pm
    i have exported quite a few clips with CS6 now. Suddenly exporting takes much longer on my Mac Pro 8 core.
    When i check CPU activity, I see only 2 cores working in full, the others either not at all or very little.
    Is there a way to have all 8 cores work and therefore encode faster?
    I also noticed that updating a small effect (like changing position of watermark) takes a long time, which was before in almost real time.
    What could be the cause of this sudden slow down?
    A 34 sec clip with no other effects than unsharp mask and a watermark takes now 5 hours to complete (before much less than 1 hour). After that, I wanted to encode an other clip and it said 10 hours… impossible!
    edit: forgot to mention:
    I am using a Mac Pro 2007 8 core, 16 Gb RAM and on the startup disk is still 20 GB space left. I set the memory (RAM share) to 13 GB. I cleared the cache inside Premier. The encoded files are written to an internal hdd with 7200 RPM
    Dorian Weber replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
