Activity Forums Adobe After Effects Export SWF from AE CS6 (having issues when my composition utilizes Phjotoshop layers)
  • Export SWF from AE CS6 (having issues when my composition utilizes Phjotoshop layers)
    Posted by Jim Yokajty on August 13, 2012 at 5:17 pm
    Having difficulty exporting to an SWF (I had no problem with prior version of AE). It appears that I’m unable to use Photoshop layers in my composition (even when I turn on rasterization). The render starts, and then as soon as it reaches a layer where the source is a Photoshop layer, the render stops. I do not receive any error messages. But the render simply stops. If I play the SWF file that’s created, the animation plays up until the point that a photoshop layer is introduced. Any thoughts?
    Miloš Homola replied 14 years, 1 month ago 2 Members · 1 Reply
  • Miloš Homola
    August 16, 2012 at 4:27 pm
    I had the same problem. I “solved” this issues.. I put everytime to the bottom layer with fractal noise (no purpose at all) but when its there, it renders ok. Strange but it works for me
