Activity › Forums › Adobe Premiere Pro › Export subtitles as time-coded transcript?
  • Export subtitles as time-coded transcript?
    Posted by Elizabeth Johnson on February 7, 2017 at 11:09 pm
    Hi all,
    I’m working on a film that requires a lot of translation. Instead of creating a timecoded translated transcript, I did much of the translation as subtitles within a Final Cut Pro 7 project file. Is there a way I can export these subtitles as a text document with timecodes? Some third party software I can use?
    I could also bring the whole project into Premiere and try to export it that way. Does anyone have suggestions? It would be too time-consuming and complicated to copy and paste them all, and too much work has been done on hundreds of hours of footage.
    Thanks for any advice!
    Elizabeth Johnson replied 9 years, 7 months ago 2 Members · 4 Replies
  • Simon Ubsdell
    February 8, 2017 at 5:08 pm
    Check out Title Exchange Pro from Spherico:
    https://www.spherico.com/filmtools/
    It does an incredible variety of things and should be ideal for your FCP 7 project.
    Don’t take it into Premiere as this will make the process a lot more tricky.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Elizabeth Johnson
    February 9, 2017 at 7:59 pm
    Thank you, Simon! Have you used it yourself? Were you able to make an actual time-coded transcript and did you have to do any modifications to it?
    Life is worth living.
  • Simon Ubsdell
    February 9, 2017 at 9:01 pm
    I’ve used it in numerous different ways and on pretty much every subtitle job we ever do.
    The simplest method for you purposes it is take an XML out of FCP 7 and turn it into a Text file that you can then edit, and turn back into whatever type of subtitle file you choose.
    But that’s just the simplest option – there are countless possibilities, depending on your needs.
    I can’t recommend it enough.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Elizabeth Johnson
    February 10, 2017 at 7:09 pm
    Thank you, that’s really helpful!!
