Activity › Forums › Apple Final Cut Pro Legacy › Export settings for DVD (big file)
Posted by Sara Blom on February 2, 2012 at 10:53 pmHi,
For burning a large file (HDV50i, 16:9, 70 minutes) on to a DVD, what export settings should I give?
I have a double layered DVD (8,5G) but my file was 14,5G after exporting.
Now I set it to MPEG4 but checking out forums I will need a special converting program for it.
Is this true or should exporting from FCP be fine?
SaraScott Moroney replied 13 years, 1 month ago 3 Members · 7 Replies -
Rafael Amador
February 3, 2012 at 3:24 amAre you trying to make an standard DVD?
5f so, use the 90 minutes High Quality DVD preset in Compressor.
DVDs do not supports MP4, only MPEG-2.
If you are trying to make a non standard DVD with HD contents, in Compressor you have “H264 for DVDSTP” presets. Those are supposed for one layer disks, so you can increase the data rate for video, but do not double it.
rafael -
Sara Blom
February 3, 2012 at 9:26 amI never worked with compressor before (shame on me..).
I’ve now set it (in compressor) at MPEG-2 90 minutes. I’ve dragged the MPEG4 file into it and it
is going to take 4 hours. Is that because it has to compress MPEG4?Is it better (and quicker) to drag the full MPEG2 file (14,5) into it?
settings: 1280×720
lineair PCM MPEG-2 video
quicktime moviethanks!
Rafael Amador
February 3, 2012 at 5:54 pmNo Sara.
Forget about the Mp4 that you have done and about MPEG-2.
Convert your HDV movie.
In Compressor, look in the folder DVD (10 groups) > HD DVD H264 60 minutes.
That preset are for single layer DVDs, so you can rise the data rate.
Set Average data-rate: 15Mbps.
Keep the same Max data rate.
Then use the Dolby preset for the audio.
You have to import the H264 and the AAC audio resultant to DVDSTP to author the DVD.
rafael -
Sara Blom
February 15, 2012 at 3:22 pmHi Rafael,
When I do so, the estimated time is 5 or six hours..I will try with a short export piece and will post what happens then…
Rafael Amador
February 16, 2012 at 5:42 pm4 or 5 hours for a multipass compression of a 70 minutes film, depending of the computer you are using, is not a crazy time.
rafael -
Scott Moroney
August 27, 2013 at 2:43 pmThank you Rafael, This is very helpful. I am preparing a 105 min file with some extras to DVD and Blu Ray. Would the same specs you mentioned apply for the DVD? Any ideas on Blu Ray prep using compressor (IO file)?
Thank you!!
