Activity Forums Adobe Premiere Pro Export Settings
  • Export Settings
    Posted by Christopher Joseph on May 23, 2007 at 3:50 pm
    I’m trying to get all my work on to my PS3 from Premiere Pro 2.0 for casual viewing. Assuming that file size is not an issue, which of the following supported file types is the highest quality with the least amount of compression?
    Memory Stick Video Format
    – MPEG-4 SP (AAC LC)
    – H.264/MPEG-4 AVC Main Profile (AAC LC)
    MPEG-1 (MPEG Audio Layer 2)
    MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
    MPEG-2 TS (MPEG2 Audio Layer 2)
    AVI
    – Motion JPEG (Linear PCM)
    – Motion JPEG (
    Mike Velte replied 19 years, 4 months ago 2 Members · 5 Replies
  • Mike Velte
    May 23, 2007 at 7:04 pm
    [cj16mm] “- H.264/MPEG-4 AVC Main Profile (AAC LC)”
  • Christopher Joseph
    May 24, 2007 at 3:11 pm
    Is that available in PP 2.0? I’m having difficulty fining it…
  • Mike Velte
    May 24, 2007 at 5:19 pm
    H264 is a codec available as a Quicktime export option, but not the many variants. I use QT Pro for better results.
    May 24, 2007 at 5:33 pm
    Are you saying that if I have Quicktime Pro installed on my computer that it will open up those other export settings?
    Thanks for the help!
  • Mike Velte
    May 26, 2007 at 9:55 am
    QT Pro is a stand alone app, it does not change Premiere’s options.
