Activity › Forums › Adobe Premiere Pro › export settings
  • export settings
    Posted by Michael Mohr on August 5, 2010 at 1:50 pm
    I hope someone can help me with this. I created a video in CS4 in HDV, I need to output using the following specs my client has asked for:
    fullscreen video at 1920 x 1080 resolution,
    Quicktime h.264 – best quality / multipass.
    Sound is 48 KHz 16b.
    They are using FCPro Apple ProRes 422 for compression.
    Do I use the H.264 Blu-ray setting for output? Any help on what the setting should be is greatly appreciated – or do I need to get more info from the client.
    I’ve never had to do this type of output before and I want to make sure I give them the correct format.
    Michael Mohr replied 16 years, 1 month ago 2 Members · 2 Replies
  • Vince Becquiot
    August 5, 2010 at 3:55 pm
    Hi Michael,
    You would use H.264, not Bluray H.264.
    For best quality, use 20 Mb/s VBR 2 Pass. Make sure you change your Pixel Aspect Ratio to square.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Michael Mohr
    August 5, 2010 at 4:08 pm
    Vince,
    Thanks a million!
