Activity Forums Apple Final Cut Pro Legacy Export setting.
  • Export setting.
    Posted by Elliot Pollaro on July 18, 2008 at 5:10 pm
    Hi guys, im needing to export a music video to be able to fit on a DATA DVD. It needs to be the best quality possible. I have tried exporting as a animation and it ends up being 6.5 gb and it also had trouble playing back. The sequence settings are set to DVCPRO HD 720p60. I need to know the right format to convert to.. and high quality. Fast responses please!
    Andrew Kimery replied 18 years, 1 month ago 3 Members · 5 Replies
  • Elliot Pollaro
    July 18, 2008 at 5:23 pm
    I have to have 3 Data DVDs made per song, and there is 3 music videos that need to be delivered today through Fed ex… hard drives is not a option.
  • Elliot Pollaro
    July 18, 2008 at 5:46 pm
    any other solution?
  • Shane Ross
    July 18, 2008 at 5:53 pm
    Dual layer disks hold 8GB…
    Shane
  • Elliot Pollaro
    July 18, 2008 at 6:04 pm
    and export at what format
  • Andrew Kimery
    July 18, 2008 at 6:39 pm
    Try MJPEG A. Still big files but not as big as animation. If you select “best” in the quality slider you get 4:4:4 but if you select slightly less than best you get 4:2:2 (smaller files and faster exporting).
    -A
