Activity › Forums › Adobe After Effects › Export series of videos based on markers?
  • Export series of videos based on markers?
    Posted by Ryan Hill on October 17, 2012 at 7:02 pm
    If I were to make a composition and then put markers in it, is there a way to automatically split it into a series of numbered videos and export those?
    To explain, say I have a composition with 15 markers, dividing it into 16 sections, and want to export each section as a video, numbered from 1 to 16. I could manually go through and set the start and end to match the markers, then export, go to the next, but I figured I check out if there’s a way to automate it.
    There might be something here I can modify to do what I want:
    https://aescripts.com/after-effects/automation/markers/
    But if there is another obvious solution I’m not thinking of, I’d love to hear it.
    Ryan Hill replied 13 years, 11 months ago 2 Members · 2 Replies
  • Walter Soyka
    October 17, 2012 at 7:06 pm
    Check out Christopher Green’s scripts [link] — you are interested in Queue_Comp_Sections.jsx.
    If it works well for you, you should consider making a reasonable donation to support his efforts.
    Walter Soyka
  • Ryan Hill
    October 26, 2012 at 2:01 am
    Done and done.
    Exactly what I needed. I had 89 output files, with as many as 20 of them in the same composition. And this was a great way to handle them.
