Activity › Forums › Adobe Premiere Pro › Export Sequence XML and transcode/export relevant clips?
  • Export Sequence XML and transcode/export relevant clips?
    Posted by Stephen Hill on June 24, 2013 at 4:41 pm
    Is it possible to export an XML of a sequence and also export Pro Res trimmed clips? I have a sequence made up of DSLR h.264 Mpeg4 clips that I would like to export as Pro Res (individual clips with handles) with an accompanying XML so I can reconform in say Resolve or Smoke 2013 (mac). So rather then transcoding all of my rushes I am instead just exporting pro res files from my final edit. I do not want to export a pro res self contained file of the whole sequence, I want individual files of each shot in pro res. Is this possible in Premiere Pro CS6? I have been into project management but there is no obvious option to transcode to new codecs/formats nor export an accompanying XML.
    Bat-sheva Guez replied 12 years, 9 months ago 2 Members · 1 Reply
  • Bat-sheva Guez
    January 2, 2014 at 9:34 pm
    Hello
    I have the same issue. Were you able to resolve this? (no pun intended)
