Activity › Forums › Avid Media Composer › Export sequence to mxf dnx120
  • Export sequence to mxf dnx120
    Posted by Dan Davis on July 17, 2014 at 1:14 am
    Hi all,
    I need to export my final sequence and audio from media composer V7.3 to MXF DNX120 for client/station. There is some ama pro res media in sequence. Not having a lot of luck, any help would be great.
    Dan
    Dan Davis replied 12 years, 2 months ago 2 Members · 2 Replies
  • Shane Ross
    July 17, 2014 at 1:34 am
    Do a Video Mix down to DNxHD120…then export. Wait…you need to deliver an MXF video file? The only way Avid does that is via OP1a, I believe. Or you can deliver the mixed down MXF file (do a REVEAL FILE) and the same for audio.
    Shane
    Little Frog Post
  • Dan Davis
    July 17, 2014 at 4:20 pm
    That’s how I played it.
    Thanks.
    Dan
