Activity › Forums › Adobe After Effects › Export raw tracking points as XML?
  • Export raw tracking points as XML?
    Posted by Ryan Hill on April 1, 2013 at 2:33 pm
    So the 3D camera tracker produces all these 2D Source track points. I would love to be able to process those track points as data in another software program.
    But it only seems to let you export the solved camera movement. Which is especially a problem if the solve fails.
    I can render the 2D track points, but to put those to use, I basically have to track them all a second time. It’d be easier to write something that tracks the little coloured Xs than to track the raw footage, but it would still be nice if I didn’t have to do that.
    Is there a different tracker plugin that produces something similar to Step 1 of the 3D Camera tracker and lets you export a full list of tracking points and each one’s movement as an XML or text file?
    Ryan Hill replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
