Activity Forums Apple Final Cut Pro Legacy Export Quicktime animation Millions of colors+ with Compressor
  • Export Quicktime animation Millions of colors+ with Compressor
    Posted by Wouter Tersteeg on March 29, 2009 at 12:15 pm
    Hello,
    I want to use Compressor to cluster the Quicktime animation Millions of colors+ render process. I have tried many times but still no alpha channel. One by one in Quictime Conversion works fine but it would be great to render the bulk when I am sleeping. Is there anybody who can help me or is it really a bug in Compressor.
    Kind regards, Wouter
    Wouter Tersteeg replied 17 years, 6 months ago 4 Members · 5 Replies
  • Bouke Vahl
    March 29, 2009 at 4:36 pm
    Sounds like a compressor bug.
    But it should be easy to applescript QT to do the job for you.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Stephan Walfridsson
    March 29, 2009 at 7:32 pm
    Try using ‘Batch Export’ from FCP instead of ‘Using Quicktime Conversion’
    Stephan
  • Jeremy Garchow
    March 30, 2009 at 6:45 pm
    What is the source of your timeline? What exactly are you trying to do?
  • Wouter Tersteeg
    March 30, 2009 at 8:06 pm
    Batch Export works great! That is the solution.
    Thanks a lot
  • Wouter Tersteeg
    March 30, 2009 at 8:25 pm
    Hi Jeremy,
    The source is 1920 x 1080 25p chromakey footage. The output is QuickTime animation Millions of colors+
    Stefan gave me the solution for a good night’s rest. So Batch Export will do the job perfect.
    Thanks a lot for your response.
