Activity Forums Apple Final Cut Pro Legacy export qt movie which matches tc on Timeline?
  • export qt movie which matches tc on Timeline?
    Posted by Emmet Reddy on August 11, 2009 at 7:36 pm
    Is it possible to export a quicktime movie which matches the timecode on my time line ie if my timeline started at 10:00:00:00 can i get my quicktime file to have the same TC ?
    Emmet Reddy replied 17 years ago 3 Members · 3 Replies
  • Shane Ross
    August 11, 2009 at 7:53 pm
    Sure. FILE>EXPORT>QT Movie (self contained) does this. And many formats you can convert to, like H.264, will retain this as well.
    Shane
  • Vince Sanchez
    August 11, 2009 at 9:36 pm
    And if that doesn’t work, you can drop the clip into the browser in FCP, select it. Go to the Modify drop down menu, select timecode, make sure the box for Source TC is checked, then type in the same start time as the original timeline or clip.
    BTW make sure the clip is on the first frame, otherwise the TC you type in will be set to the point at which the clip wiper is sitting. This is actually a good thing, because if you know the timecode of a certain but not the start timeof the clip you can park the wiper on the known frame, input timecode and you’re good to go.
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
  • Emmet Reddy
    August 12, 2009 at 3:28 pm
    Cheers Guys
