Activity Forums Apple Final Cut Pro Legacy Export QT movie, FCP 5.0 Crashes
  • Export QT movie, FCP 5.0 Crashes
    Posted by Ryan B on August 26, 2005 at 4:10 pm
    Hello all,
    From my Aurora 10bit Anamorphic 16:9 timeline I am having an bigtime export issue when I try to “export quicktime movie.” No matter if “recompress all frames” or “make movie self contained” is checked, or the combo of the two FCP 5 crashes. But if I export the same timeline without the anamorphic setting turned on in the sequence settings, it exports fine.
    I know that just the other day I was having the same issue with some Aurora 8bit SD footage as well, just lock up after lock up. I’ve trashed preferences, tried re-setting premissions to my disks, but none of that seems to help. Has anyone else had problems like these, and can maybe offer a solution??
    Ryan Berkey
    G5 Dual 2.5
    4.5gb RAM
    FCP 5 Studio
    Aurora Pipe Studio
    D-Beta, Beta Sp, HDV, DV
    Jerry Hofmann replied 21 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 27, 2005 at 2:12 am
    Have the latest drivers from Aurora? Might post this in the Aurora forum too… might be a certain combo of software that works best…
    That said, if you didn’t do a clean install of Tiger and FCP 5 over it, that too could be the issue.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
