Activity › Forums › Media 100 › Export problems
  • Export problems
    Posted by Frank Cann on May 10, 2011 at 7:54 pm
    Running M100 7.1
    Trying to export a QT file from range. If I export a short clip – it works fine. If I do the same export with a longer range – upon completion it tells me that it’s not a movie file to open.
    I have tried different codecs with the same results.
    Any suggestions?
    Is this a M100 or a QT7 thing?
    Floh Peters replied 15 years, 4 months ago 3 Members · 4 Replies
  • Floh Peters
    May 12, 2011 at 9:18 am
    Are you really running Media 100 V7.1? Interesting. If this is the case, you could hit a 2GB filesize limit which was around in earlier OS versions. Or maybe your drive is formatted HFS and not HFS+, which also allows only 2GB. Try exporting short ranges, increase the length and look where it fails.
  • Frank Cann
    May 12, 2011 at 12:57 pm
    Running 1.7 – sorry about that.
  • Dave Mccarthy
    May 13, 2011 at 12:39 am
    That’s a relief!
    What happens if you export the entire program?
    Can you isolate the failure to a specific segment of the range? In other words, maybe there is a bad section of the program that would fail no matter how short the range.
  • Floh Peters
    May 13, 2011 at 12:17 pm
    Another idea: you are not trying to export to an USB-Stick or a windows formatted drive? They still have a 2GB (or maybe 4GB) filesize limit on MacOS, as far as I know.
