Activity › Forums › Adobe Premiere Pro › export problem premier cs4
  • export problem premier cs4
    Posted by Mahesh Dood on April 7, 2009 at 5:54 am
    hi
    i got your previous message,thanks. but i have a small clarification: i am not exporting at 1080p, but at 1920x1080i/ 50i, so do i still need to have a high end machine for the exported file to play smoothly?
    the other problem is that the exported file does not maitain the correct pixel aspect ratio when i play it on any player like media classic or vlc, the picture gets either long or too wide.the picture is distorted. dont know what the problem might be. need your help?
    the same project when export at 1440x1080i anamorphic, the exported video has no ditortion and plays fine.
    i really dont know what to do
    please help
    mahesh
    Eddie Lotter replied 17 years, 6 months ago 2 Members · 1 Reply
  • Eddie Lotter
    April 7, 2009 at 4:58 pm
    [mahesh dood] “do i still need to have a high end machine for the exported file to play smoothly?”
    Simply put: The better the machine, the better the playback performance.
    [mahesh dood] “the picture gets either long or too wide.”
    It sounds like you’re using the wrong pixel aspect ratio (PAR). For 1920×1080 your should be using a square (1.0) PAR.
    Cheers
    Eddie
