Activity › Forums › Adobe After Effects › Export problem mpg
Export problem mpg
Posted by Filippo Centenari on February 11, 2008 at 2:13 pmHy
I made a project with 768×1366 frame size and I need to export an mpeg at this resolution but when I try , using MPEG 2 codec, the video rendered is 720×576.
Is there an option to change the frame size?I use After Effect 8
thanks a lot
filippoSteve Roberts replied 18 years, 7 months ago 3 Members · 10 Replies -
Steve Roberts
February 11, 2008 at 3:37 pmMPEG-2 is for DVD, and it can only be one of two sizes: 720×480 or 720×576.
What type of machine will you use to play back your final movie? Computer? DVD player?
Filippo Centenari
February 11, 2008 at 3:47 pmthanks for the answer,
i Need to put this video on a Plasma using Scala Infochannel.
the video is really simple and it’s 15seconds but any time I try to export in the other codec supported by scala (windows media video)I always have a bad quality.
I don’t know how to set in order to have the best video setting for the quality.thanks really
filippo -
Filippo Centenari
February 11, 2008 at 3:53 pmI understand the other codec supported for my player (Scala Infochannel) is wmv.
But I can’t find a good export setting, I need to know the best way in order to export wmv at the best quality.
if you know i’m here!!
thanks
filippo -
Filippo Centenari
February 11, 2008 at 4:08 pmok so 2 last questions:
what kind of export I use in AE? tga sequence?
what program for the final render?
thanks a lot
filippo -
Filippo Centenari
February 11, 2008 at 4:24 pmOk will try this way, I’m on PC not Mac.
Any other software or only Sorenson?I exported the video as you said but the quality is not so good, in my video there are some psd file and exported have some artifacts..
Filippo Centenari
February 11, 2008 at 4:36 pmsorry!
the video is ok!
it was my fault, now I will try to encode it using sorenson trialthanks
Brian Berneker
February 12, 2008 at 11:02 amMPEG2 is not just for DVD. It’s used for all HD standards as well. Sounds like our friend wants to output to a an HD television that has a 1366×768 format display.
Brian Berneker
February 12, 2008 at 11:03 amAre you using Export from the FILE menu, or are you using the render queue/manager? You may be able to get more control over the compression and size settings.
Also, if you export to animation codec and still want to use MPEG2, I suggest using Episode Pro. It’s a high quality, FAST encoder. Why apple’s compressor takes SO LONG to compress video is beyond me…
Filippo Centenari
February 12, 2008 at 11:11 amThnaks for the answer
I found a solution using Animation (Quictime) export in AE and then using Sorenson.
But I will lokk for your direction tooI use render manager and not export in AE but the frame size of MPEG2 is fixed at 720×576 or NTSC
