Activity › Forums › Adobe After Effects › Export problem!!!
  • John Cuevas
    December 31, 2011 at 11:50 am
    Few things you can try. Make a lossless animation(I prefer QT Animation) and then take that into media encoder and render to your final resolution. Encoder does multi-pass encoding so you should get a better final file.
    If the first approach also gives you problems another way would be to make a tiff, pict or jpeg sequence. If it comes out okay, great, but if not – you can find the offending frames, locate the spot in the timeline and replace them using “cntl+alt + s”.
    Perhaps others here might have some insight on why your render is doing that, but I haven’t seen that particular issue before.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Tudor “ted” jelescu
    December 31, 2011 at 12:58 pm
    Are you using Time Remap on one or more of your layers?
    Tudor “Ted” Jelescu
    Senior VFX Artist
