Activity › Forums › Adobe Illustrator › Export Photoshop CS to Illustrator CS
  • Export Photoshop CS to Illustrator CS
    Posted by Imjkw143143 on February 17, 2007 at 5:38 pm
    I need to export all my layers from Photohop CS to Illustrator CS. I will need to be ablet to edit each layer as well. How can I do this the most efficient way. I simply opened the PSD in IA but all I got was one layer and none of it was editiable. I do not know if this can even be done. I sure could use some simple yet detailed assistance.
    Thanx…
    Mike Gondek replied 19 years, 7 months ago 2 Members · 1 Reply
  • Mike Gondek
    February 19, 2007 at 5:25 pm
    Try saving or printing to a pdf from photoshop and opening the pdf in illustrator. Obviously check to keep vector objects and layers intact. Good Luck, let us know how this turns out.
