Activity Forums Apple Final Cut Pro Export or share in Final Cut Pro X drops audio
  • Export or share in Final Cut Pro X drops audio
    Posted by David Chaytor on April 18, 2014 at 9:24 pm
    Hi there:
    I have tried exporting a 6:30 file twice now with the Trial version of Final Cut Pro X, using export Master File. Each time the audio completely drops out at exactly the 5:56 mark. It did the same thing when I tried share to YouTube.
    Is there some sort of time limit to exports in the trial version?
    Running Final Cut Pro Trial on 15″ MacBook Pro with Retina Display, 2.3Ghz, 512 Flash Storage, 16GB memory.
    Any help will be appreciated, thanks!
    Jeremy Garchow replied 12 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    April 19, 2014 at 2:15 am
    Try trashing your render files and try again.
