Activity › Forums › Apple Final Cut Pro Legacy › export options
export options
Posted by Tommy V. wier on June 30, 2007 at 3:25 amclient wants 18 2-hour dv tapes converted to quicktime movies. It will take forever! Is H.264 fastest/best option for export?
Russell Lasson replied 19 years, 2 months ago 2 Members · 3 Replies -
Russell Lasson
July 2, 2007 at 6:38 pm[cahaba] “Is H.264 fastest/best option for export?”
Fastest, no. Best quality, probably (depending on your settings). What type of computer do you have? Do you have a capture card? What size of files does the client want (how much space are they expecting to take up)?
If you have a capture card, you might be able to capture straight to H264 using FCP or maybe even QT Pro or iChat. That would save quite a bit of time.
-Russ
Tommy V. wier
July 2, 2007 at 7:08 pmpart of the problem is working thru a third party who has client
I have dual 2 ghz powerPC G5 1.5ghz ddr sdram- no capture card (coming thru firewire)I can’t imagine they would want all these huge files- I’m trying photo jpeg (digitize & export) but I haven’t used it before so I don’t know limitations for end user
Russell Lasson
July 2, 2007 at 7:38 pmTry using QT Pro or QT Broadcaster to see if you can digitize from FW directly to a manageable file.
-Russ
