Activity Forums Adobe After Effects export OMF from AE CS4 on a mac?
  • export OMF from AE CS4 on a mac?
    Posted by Kyle Romaneck on March 10, 2010 at 4:48 pm
    Hi all. I’m working on an project where I cut up some footage into a montage within AE. Now the audio engineer on the project wants an OMF of the audio.
    There doesn’t seem to be any OMF export option for mac’s version of CS4. Is there any other format that could work? Can I at least export an EDL and reconstruct in some other program?
    Zameer Tamboli replied 11 years, 7 months ago 3 Members · 3 Replies
  • Kevin Camp
    March 11, 2010 at 3:47 am
    i don’t believe that you can export an omf from the mac version of ae… there is this from the manual:
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103a4f2dff7-79b9a.html
    but it is for windows…
    i’d let the audio engineer know that it’s not possible to give him/her an omf from the mac version of ae, and ask for other options… (there are always other options).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kyle Romaneck
    March 12, 2010 at 4:00 pm
    Thanks for the tips guys. I ended up just exporting the comp the premiere pro and exporting an OMF out of that.
  • Zameer Tamboli
    February 5, 2015 at 3:10 pm
    IF YOU ARE WORKING WITH THE SEQUENCE ,THAT AUDIO FILES COMES WITH THE VIDEO FILES AUDIO SOURCE
    ( EMBEDDED AUDIO WITH THE VIDEO E.G. 5D CAMERA .MOV FILE WITH THE INTERNAL CAMERA MIC AUDIO.)
    THEN YOU SHOULD NOT EXPORT .AAF …
    BECAUSE WHEN YOU IMPORT THAT AAF IN TO PROTOOLS IT WILL ASK YOU TO LOCATE ORIGINAL SOURCE AUDIO MATERIAL.
    IN THAT CASE PROTOOLS CANNOT RELINK THAT AUDIO WHICH IS EMBEDDED WITH VIDEO FILES. 🙁
    AND YOU CANT WORK 🙁 🙁
    SO DONT WORRY HERE IS THE SOLUTION
    EXPORT ONLY .OMF WITH TRIMED AUDIO + HANDLE LENGHT OF 100 FRAMES.
    BECAUSE SINGLE OMF FILE SHOULD BE BELLOW 2 GB IN SIZE ..(OMF SIZE LIMIT)
    AND DONT FORGOT TO HANDOVER AUDIO FOLDER WHICH IS AUTOMATICALLY CREATED WHEN SAVING .OMF
    ;0 🙂
    IN END RESULT SOUND GUY HAPPY
