Activity Forums Apple Final Cut Pro Legacy Export not full-res
  • Export not full-res
    Posted by John Godwin on June 30, 2009 at 4:13 pm
    I have an FCP project with DV timelines. I let FCP set up the timeline to match the video. It looks perfectly fine on the canvas, when it’s set to 100%. It also looks perfect on the monitor through the Kona 3 card.
    When I export video as a self-contained .mov, using current settings, though, the result looks lo-res and pixelated. It almost appears as if it’s only exporting one field.
    I can export through QT conversion as, say, 640×480 VGA, and it comes out full-rez.
    Xdcam ex timelines in the same project export correctly.
    This is on a mac pro, FCP 6.0.5, QT and OS are just prior to the latest upgrades.
    I suspect I have some simple setting wrong somewhere but I can’t figure it out. Thanks in advance ….
    Best,
    John
    John Godwin replied 17 years, 2 months ago 1 Member · 1 Reply
  • John Godwin
    June 30, 2009 at 4:56 pm
    It was the “use hi-res when available” setting in QT….
    Best,
    John
