Activity › Forums › Adobe Premiere Pro › Export non CMX EDL?
  • Export non CMX EDL?
    Posted by Brian Sternkopf on May 13, 2019 at 5:50 pm
    Does anyone know if there is a way to export an non CMX EDL out of Premiere Pro CC, or if there is a way to get more that 4 tracks at a time from a CMX EDL?
    Thanks;
    Brian
    John Pale replied 7 years, 4 months ago 3 Members · 5 Replies
  • Shane Ross
    May 13, 2019 at 6:04 pm
    EDLs are VERY VERY VERY VERY old things. I mean, OLD old. Designed for linear tape bays, and 4 channels of audio ws the max for those. Did I mention OLD? AAF and XML are the newer options that offer many more tracks of audio. ANy reason you are using an EDL instead of those?
    Shane
    Little Frog Post
  • Brian Sternkopf
    May 13, 2019 at 6:10 pm
    Thanks for your response-
    I need to make a cue sheet for all sound I used from Source Audio music library and they can search there database for me if I can upload the track info in a file format. It doesn’t need to be an edl, but I’m not sure what else Premire exports that would have just audio track info to upload to Source Audio.
  • Shane Ross
    May 13, 2019 at 7:24 pm
    OK, well…you can make sure your music is on only four tracks when you make the EDL. I make a practice of limiting my music to 2 tracks…THREE at most.
    BUT…if you need a MUSIC CUE sheet… I have a better solution.
    Export an XML, and get this INCREDIBLY AMAZING app that will bring in ALL your video, ALL your audio, and make a report of clips used, clip names, their in and out points, sequence in and out points, a list of text, audio cues. You can limit what audio tracks to select so you can make a separate music cue sheet
    SEQUENCE CLIP REPORTER
    https://intelligentassistance.com/sequence-clip-reporter-cc.html
    I swear by this thing.
    Shane
    Little Frog Post
  • Brian Sternkopf
    May 13, 2019 at 8:30 pm
    Thanks- I’ll look into it.
  • John Pale
    May 14, 2019 at 12:16 pm
    Looks like Source Audio offers an Adobe Panel you can install to create cue sheets for you from within Premiere.
    https://www.sourceaudio.com/adobe-panel/
