Activity Forums Apple Final Cut Pro Legacy Export MXF File
  • Export MXF File
    Posted by Sascha Engel on June 10, 2014 at 4:40 pm
    Dear FCP Friends,
    I have to deliver for a Record Company in Belgium a weird master file: An MXF Container with XDCAM HD422 50Mb/s (see attached image).
    When I export an XDCAM HD422 from FCP 7, the container is a .MOV file, not a MXF.
    Any ideas how I could get that? I can output from my system over following apps: FCP 7 & X, PPro, Compressor, AE, DaVinci and AVID.
    Any suggestion would be great.
    Thanx.
    Greetings
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Max Sainvil replied 9 years, 1 month ago 4 Members · 20 Replies
  • 20 Replies
  • Shane Ross
    June 10, 2014 at 5:38 pm
    You don’t export a QT movie…you go FILE>EXPORT>XDCAM. And then you get this interface:
    (oh, you need to switch audio to DUAL MONO in the Sequence Settings, audio tab before you export)
    Choose the required settings and export.
    Shane
    Little Frog Post
  • Sascha Engel
    June 10, 2014 at 5:52 pm
    Thanx Shane, I will try it like that
    Sascha Engel
  • Sascha Engel
    June 10, 2014 at 5:59 pm
    It refuses to to it in 16 bit, it requires to change to 24-bit TL settings. Any idea why?
    Sascha Engel
  • Shane Ross
    June 10, 2014 at 6:01 pm
    Because that’s one of the requirements of OP1a MXF deliverables…I suppose. I mean, it says “you must do this.” Just do it.
    Shane
    Little Frog Post
  • Sascha Engel
    June 10, 2014 at 6:03 pm
    Getting following error message:
  • Shane Ross
    June 10, 2014 at 6:04 pm
    HOw much room is available on the drive you are exporting to?
    To be honest, I’ve only done this once…4 years ago.
    Shane
    Little Frog Post
  • Sascha Engel
    June 10, 2014 at 6:07 pm
    Can’t be the disc space:2,5 TB Free 🙂
    Besides, I do not have the export options like you, if I go to export, I have the option to go to SONY content browser,
    and from there I get the window you posted.
    No matter to which volume I wanna export to, I get this error log 🙁
  • Shane Ross
    June 10, 2014 at 6:09 pm
    What version are you running?
    Shane
    Little Frog Post
  • Sascha Engel
    June 10, 2014 at 6:11 pm
    Mac OS? 10.8.4
    FCP 7.0.3
  • Sascha Engel
    June 10, 2014 at 6:23 pm
    Found the problem: I have to create 8 Mono Channels, even if I have only 1 Stereo with files on it.
