Activity › Forums › Adobe After Effects › Export MPEG From AE
Export MPEG From AE
Posted by Rashid Shahzad on July 3, 2005 at 6:24 pmi want to expoert my composition in mpeg format for burning a VCD so please tell me in detaile step by step that how can i do this.
Filip Vandueren replied 21 years, 2 months ago 3 Members · 4 Replies -
Stephen
July 3, 2005 at 6:40 pmHi
you’ll need to change your rendering options. To do that press “ctrl+m” (if you have a mac “option+m”).
then you will see “output module”(on the left) clik on the word on its right (in blue)
and you will get the “output module settings” change the format to the one you wantIt only has mpeg2 but that will work, you can then burn a SuperVcd
Then clik the Render button but make sure u know where your file is going(u can see that in “output to”)
cheers
Stephen
Rashid Shahzad
July 3, 2005 at 8:07 pmhi
dear there is no any mpeg 2 in the list so what shoul i do now../ -
Stephen
July 3, 2005 at 8:57 pmnormally there is mpeg 2
u need to clik on the blue word next to “output module” and not the arrow.
Then a new window will pop up “output module Settings” and there it says “format” thats where you should see it
if you don’t see the list or Mpeg 2 in it..well I can’t really help u…
cheers
stephen
Filip Vandueren
July 3, 2005 at 9:29 pmRendering to MPEG-2 and MPEG-2 DVD is a 6.5 Windows only feature
