Activity Forums Adobe Premiere Pro Export movie WITHOUT encoding.
  • Export movie WITHOUT encoding.
    Posted by Darrell Boeck on July 1, 2009 at 8:21 pm
    Hello,
    I am working on a XDCam timeline, with a clip that has been rendered (a green bar is over it). What settings do I use to export the movie without having to re-encode it?
    With Premiere CS3, a several minute clip only took a few seconds – since nothing needed to be encoded. Any idea how to do this with CS4? With each setting I try, it takes about 20 minutes to export a 2 minute, already rendered clip.
    Thanks for the help.
    Darrell
    Darrell Boeck replied 17 years, 1 month ago 4 Members · 6 Replies
  • Vince Becquiot
    July 2, 2009 at 12:58 am
    In the export settings, look for that little contextual menu (center right), there is an option there to use preview files.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Darrell Boeck
    July 2, 2009 at 12:45 pm
    Thank you. That is helpful. But what setting would I use so the export is the same format as the source footage, which is XDCam?
    Sorry if I seem so ignorant. After 20 years of working with SD, HD has quite the learning curve.
  • Vince Becquiot
    July 2, 2009 at 3:25 pm
    Well, I’m as ignorant as you are since I actually never used that feature… and I bet you are looking for that XDCam export setting, me to…
    Well, I don’t work in XDCAM, but if you install the Sony drivers you should have a Mainconcept export option in the file menu.
    Says here on page 11:
    https://pro.sony.com/bbsccms/assets/files/micro/xdcamex/downloads/Premiere_XDCAM_Workflow_v9_6.pdf
    Good luck !
    Vince Becquiot
    Kaptis Studios
  • Robert Braunstein
    July 17, 2009 at 2:20 pm
    Vince,
    I’m just getting started with PP CS4 and I’m trying to figure out how to simply export a movie as it was done in previous versions. Do you have to use the encoder or can you just export a movie? I am simply editing in SD and want to make an avi file from my timeline. Right now it’;s taking me to the video encoder which takes a much longer amount of time.
    thanks!
  • Matt Jesse
    July 27, 2009 at 5:14 pm
    bump. I would like to know if this is possible too.
  • Darrell Boeck
    July 27, 2009 at 6:37 pm
    I still have not figured out how to do this – and this feature is HUGE to me. I would reguarly export a movie that had filters/etc to use elsewhere on the timeline, or apply more filters.
    Even with footage that is real-time (no red bar over it), it takes FOREVER to export a clip that only took seconds with CS3.
    Darrell
