Activity Forums Apple Final Cut Pro Legacy Export mistery! why an 1920×1080 come up stretched?
  • Export mistery! why an 1920×1080 come up stretched?
    Posted by Sara Petrai on October 12, 2012 at 11:20 am
    Hi there,
    I’m having this problem recently which I can’t understand and drive me mad!
    The 1920×1080 export from FCP comes up stretch!! as the SD anamorphic/non anamorphic issue but it’s all in HD and it can’t be possible!
    If I play the export on VLC it does fix it but preview and quick time play it as an 1920×1080 sequence stretched!!
    How is that possible?
    I do have different raw file (but all HD or HDV)
    1920×1080 apple pro ress
    1920×1080 XDCAM EX 1080p25
    1440×1080 HDV1080i50
    few clip on 720×576 dvpal
    Timeline setting
    1440×1080 aspect ratio HD(1440×1080) 16:9
    pixel aspect ratio HD (1440×1080)
    field dominance None
    frame 25
    compressor apple pro res 422(HQ)
    the export comes up in 1920×1080 but stretch.
    what I’m doing wrong?!
    here a snap shot with some info
    thanks for your help!
    Ryan Holmes replied 13 years, 10 months ago 2 Members · 1 Reply
  • Ryan Holmes
    October 12, 2012 at 3:37 pm
    Looks like you’re exporting out a HDV sequence. HDV has a different PAR (pixel aspect ratio) then 1920×1080 HD and different from 720×576 PAL. That’s probably why your stuff is looking stretched. The PAR is wrong, given that you setup your timeline as a HDV sequence.
    I would recommend transcoding your footage to one common format. Either 1080HD or DVPAL depending on your output and needs.
    Other options:
    — Change your timeline settings to a standard 1920×1080, square pixel aspect. This will require you to readjust the HDV and PAL clips on your timeline (possibly scale them to fit).
    — Change your export settings to do the conversion to 1080HD
    Ryan Holmes
    http://www.ryanholmes.me
    vimeo.com/ryanholmes
