Activity Forums Adobe Premiere Pro Export master format for Adobe Prem Pro
  • Export master format for Adobe Prem Pro
    Posted by John Mcmullan on November 13, 2011 at 11:12 am
    Gday peeps,
    Am I going crazy, or is this webpage incorrect about the appropriate format for making a master from Prem Pro? To summarise he says that the best master is in the native camera codec (e.g. P2 or AVCHD, etc).
    https://crookedpathfilms.com/blog/2010/03/30/adobe-premiere-pro-what-are-the-best-export-settings/
    I commented on the post with a correction that a master would be more appropriate in uncompressed AVI or ProRes or such as a less compressed file, but the blog owner emailed me and told me I was wrong and that now because Premiere can edit in native that it is much better to export natively.
    Is this true?
    Thanks peeps.
    JM
    Ann Bens replied 14 years, 10 months ago 3 Members · 3 Replies
  • John Mcmullan
    November 13, 2011 at 3:12 pm
    Is OK, sorted the issue.
    Cheers
    JM
  • Richard Crook
    November 13, 2011 at 3:15 pm
    Hey John, thanks for the correction, and the post was updated. Intermediates or uncompressed should be used. Originally I had put that in some case to save space, the option would be to export a p2 movie back to p2. I removed that part to avoid confusion. I wouldn’t tell someone to export a master back to avchd though. That’s not possible in Premiere anyway.
  • Ann Bens
    November 14, 2011 at 1:06 am
    Actually you can make an avchd file if you wanted to.
    Make a BluRay folder and rip the m2ts file from the stream.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
