Activity › Forums › Apple Motion › Export masks in Motion 4?
Posted by Austin Calam on July 17, 2010 at 7:50 pmHow do I Export a Mask from Motion 4 to be edited in Final Cut Pro 7?
Austin
Mark Spencer replied 16 years, 2 months ago 2 Members · 5 Replies -
Mark Spencer
July 18, 2010 at 12:28 amCan you explain more about what you are trying to accomplish? Not clear why you would every want to do that.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Austin Calam
July 18, 2010 at 2:15 pmI want to be able to use the use the mask like a matte in FCP. I would use a matte but I want a more detailed matte.
does that help?
Austin
Mark Spencer
July 18, 2010 at 3:21 pmWhy not just send the clip you want to mask to Motion and do it there?
But if you really want to do it the hard way, you could use a shape instead of a mask, then import your Motion project, place it over your clip in FCP, and use a Travel Matte Alpha blend mode.
Mark Spencer
Mark Spencer
July 19, 2010 at 3:48 amSame way you import anything else into Final Cut – File > Import > Files for example. Just select the Motion project.
Mark Spencer
