Activity › Forums › Apple Final Cut Pro Legacy › Export logging list from L&T
Posted by Björn Obenius on January 19, 2011 at 1:47 pmHi!
I am logging a big amount of AVCHD files and I would like to be able to export the list from Log and Transfer, but I can’t find a way to do that. Is it not possible? I don’t want to transfer the files yet because I am not sure which clips to use.
Björn, SwedenJeremy Garchow replied 15 years, 7 months ago 2 Members · 7 Replies -
Jeremy Garchow
January 19, 2011 at 2:15 pmSorry, no. Your clips aren’t logged until they are transferred.
Björn Obenius
January 19, 2011 at 2:17 pmThanks, at least I know now. But It’s a pity…
Björnvidiot
Björn Obenius
January 23, 2011 at 1:35 pmHi!
Now I discovered another thing: When I create a new FCP project and open the files I had logged in another project, the new project L&T window can’t read my logging notes!That´s something everybody ought to know – and perhaps I was the only one who didn’t – and then the question arises: How can I log clips so that theese metadata (?) follows the original P2 or AVCHD files and not only appear in one special FCP project’s L&T window?
Regards, BJörnvidiot
Jeremy Garchow
January 23, 2011 at 11:18 pmIf using P2, you need to edit the P2 metadata and then send the MXf files over natively. I use P2 flow and MXF4mac just for this. It works great.
The metadata should stick with the project, but the trick is you have to TRANSFER the footage inorder for the metadata to stick to the project. You can’t log and not transfer. You will lose the metadata.
Jeremy
Björn Obenius
February 15, 2011 at 8:12 pmAt last I have had time to test this:
open log and transfer, log AVCHD or P2 clips, transfer to FCP, save and shut down, delete the clips by going into the FinalCutPro Capture Scratch File and delete the clips from there.
THEN when I open the project again, open log and transfer: all my logging notes have disappeared.Obviously I need to buy an application that can change the metadata in a way that the changes stay on while I work with the clips in FCP. WHich one works best?
And the free Panasonic P2CMS makes me wonder – it isn’t even correct English in it. I don’t want to seem cocky – my English is far from perfect – but they should get it right on an international level I think.
Regards, Björnvidiot
Jeremy Garchow
February 15, 2011 at 8:23 pm[Björn Obenius] “THEN when I open the project again, open log and transfer: all my logging notes have disappeared. “
But they are still in the project, correct? After you have logged and transferred, those notes are now in the project. You then batch capture all the material if you need the media back.
[Björn Obenius] “Obviously I need to buy an application that can change the metadata in a way that the changes stay on while I work with the clips in FCP. WHich one works best?”
For P2, check out p2 Flow. Metadata moves with the footage, not just the FCP project file. Not sure about AVCHD.
[Björn Obenius] “And the free Panasonic P2CMS makes me wonder – it isn’t even correct English in it. I don’t want to seem cocky – my English is far from perfect – but they should get it right on an international level I think.”
While my English is questionable at best, yes, P2CMS is not localized very well. You should check out the manual. 🙂
