Activity Forums Apple Final Cut Pro Legacy Export log markers to a text file
  • Export log markers to a text file
    Posted by Nathan Rittenhouse on February 21, 2008 at 6:18 pm
    I am working with some interview footage that I have marked-up extensively at the clip level (i.e. not in a sequence yet) using generic comment markers (not compression or chapter) to help me find my way back through the dialogue for editing. The clips with the markers are multiclips (not sure if that makes a difference.)
    I need to get these markers (marker name, comments and time code) into a legible text file. The closest I’ve gotten is an XML export of the multiclip which I opened in a text editor and found my markers listed amidst a ton of extra text stuff, but with un-decipherable time code notations.
    If this is an impossible or unduly complicated task and you have found a different process for logging information and sending it to a producer or client I’d love to hear.
    Nate
    Diego Barraza replied 14 years, 7 months ago 10 Members · 15 Replies
  • 15 Replies
  • Jerry Hofmann
    February 21, 2008 at 8:24 pm
    The software design in FCP dictates you put this information in the myriad text enterable columns in the Browser. These columns can be exported to a tab delimited file that opens real keen in excel or numbers.
    Course, that doesn’t help you now. I’m impressed you found them that way. Bravo. I’m betting you can’t access this any other place without really hacking into the code.. wouldn’t wanna do that myself..
    Figure cut and paste? But do it into FCP columns as you do this… ? then export the colums you need. I’m with you though, this is a feature waiting to happen. log over picture is nice for sure.
    i.e. never needed to do this, nor in all my readings of posts (there’s a few too) I’ve never heard of someone needing o do this. Get thee to an intern. sorry man.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Hofmann
    February 21, 2008 at 8:25 pm
    I hope someone here can prove me wrong.
    Jerry
  • Andreas Kiel
    February 22, 2008 at 1:28 am
    Have a look at my free unsupported readXML – https://www.spherico.com/filmtools/readXML/index.html
    Regards
    Andreas Kiel
    Spherico
  • Nathan Rittenhouse
    February 22, 2008 at 4:35 pm
    That did what I needed it to do – Thanks Andreas. I collapsed my multiclips, put them in a sequence, xmled them to your readXML and printed them to a PDF file.
    Thanks again,
    Nate
  • Stavros Stavrides
    February 25, 2008 at 9:04 pm
    You’re a genius. Your “readXML” works beautifully! I selected the marked sequence in FCP, exported to XML. I set your app to “Marker sequence + video” and clicked ‘Load XML” and selected ‘sequence’ in the exported file. All the markers and TC’s appeared as promised,matching the FCP columns. I then hit “Export all Markers”. Here’s the kicker: I opened an excel worksheet, hit “paste” and voila. Pure genius. Thank you. Donation in progress.
  • Andreas Kiel
    February 26, 2008 at 10:20 am
    Thanks for the compliments.
    Andreas
    Spherico
  • Neal Sickles
    February 5, 2009 at 4:22 pm
    Thank you Stavros for instructing us on how to use it for exporting markers. This app is so incredibly helpful when you need to produce a rundown list of all lower 3rds, chapter titles, and animation notes for graphic designers to work from.
    Cha’ching.
  • Lucia Grillo
    March 9, 2009 at 4:23 pm
    I followed Stavros’s directions several times but I keep coming upon one of the following:
    a pop-up window titled “Select XML node” that indicates there is more than 1 XML and that I should choose one from the list, but nothing shows up on the list! or
    it says “checking XML” and does nothing.
    Can someone please tell me what I’m doing wrong?
    Lucia
  • Jeffrey Mcmahon
    April 7, 2009 at 12:54 am
    I am having the same problem as Lucia and would love a resolution. Along a similar line, I was trying to find a way to import multiple clips into ReadXML simultaneously and get a batch file out, but it freezes up – is this possible in some way?
  • Andreas Kiel
    April 7, 2009 at 1:17 am
    readXML only works on 10.4.11.
    unfortunately I lost the source code when “some people cleaned up my office”.
    But there is the markerTool on my website, which is not that complexas readXML had been – and it’s only for markers.
    https://www.spherico.com/filmtools/markerTool
    Andreas
    Spherico
