Activity Forums Adobe Photoshop Export layers from photoshop with scripts – no serial numbers
  • Export layers from photoshop with scripts – no serial numbers
    Posted by Brian Wagner on February 22, 2010 at 6:51 pm
    When I export layers in photoshop using the “export layers to files” script it includes a serial number. Is there a way to use this script without adding the serial numbers?
    Brian Wagner replied 16 years, 6 months ago 2 Members · 3 Replies
  • Mike Gondek
    February 23, 2010 at 7:10 pm
    good question, I remember running into this before.
    Try imageready, I believe there was an option to use layer names.
    If it does not let us know how you would want the files to be named,a s that might help locate a solution.
    Either that or I downloaded on utility on the pc for file renaming that had more features than batch rename in bridge.
  • Brian Wagner
    February 23, 2010 at 8:07 pm
    Thanks for responding. I work on CS3 and CS4, imageready is discontinued on those suites.
    If I export the layers from photoshop I get a serial number as the prefix, I saw that I could rename in bridge but it doesn’t take off the serial number prefix.
    Any other thoughts? Thanks.
  • Brian Wagner
    February 23, 2010 at 8:09 pm
