Activity › Forums › Apple Motion › Export issues
Export issues
Posted by Pedro De la fuente on May 1, 2009 at 4:29 pmHi guys, just having a wierd problem with my export in motion. Once I created the animation and previewed with the RAM preview everything looks perfect. As soon as I start the export process it looks like Motion is missing some of my layers. It just exports the background and the titles I am using. I dont know if this is due to a lack of GPU (Im running on a 128mb Video card). But I was expecting that although it would take me more time to export, the exported video should look like the RAM preview.
any idea of what it is the problem?
Much appreciated.
Stephen Smith replied 17 years, 4 months ago 2 Members · 10 Replies -
Stephen Smith
May 1, 2009 at 4:50 pmThat is so crazy, that just happened to me for the first time every last night. I closed out Motion and then re-opened it and re-exported it and everything was just fine.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Pedro De la fuente
May 1, 2009 at 4:58 pmDo you think it might have something to do with GPU versus Motion Blur?
I just turned the Motion Blur off and it worked fine. If I have it on it doesnt work.
What do you think?
Stephen Smith
May 1, 2009 at 5:03 pmThat’s the craziest thing. My project did not have a motion blur. Did you try closing out motion and then re-opening it?
Pedro De la fuente
May 1, 2009 at 5:16 pmYeah, a few times already. Cant really understand. To me the logical thing is that if the software can Preview it with RAM it should be able to export. I am not using a crazy codec or anything, just animation or PRORES422.
Will do a few more experiments and let you know. really didnt count with this one.
Pedro De la fuente
May 1, 2009 at 5:35 pmOne thing I realised is that if you export the comp using the exact same settings as your project things work and the render is quick. The only problem is that I cannot turn Motion Blur on cause I have not worked with Motion Blur on in my proj.
Stephen Smith
May 1, 2009 at 5:40 pmSorry, I thought you said you took the Motion Blur off and everything worked. Any way of posting the project file in this forum?
Pedro De la fuente
May 1, 2009 at 7:10 pmYes I have turned the Motion Blur off and then it worked.
project file:
40_starringdanielle.motn.zip -
Pedro De la fuente
May 1, 2009 at 7:25 pmThanks very much for looking into this with me mate. Can you let me know which set up you are working on?
Do you think that could have something to do with my 128mb video card?
once again, thanks for your time.
Stephen Smith
May 1, 2009 at 7:35 pmSorry, it exported out just fine on my computer, keep in mind I’m missing the images and paper bkg. Not sure what is going on but this is not normal.
Stephen Smith
May 1, 2009 at 7:48 pmYou may want to re-post this question so some fresh eyes can take a look and see if someone can figure this bug out. As for my setup:
Mac Pro, Quad-Core Intel Xeon, 8 GB 667 MHz DDR2 FB-DIMM – I hope that helps.
