Activity Forums Apple Final Cut Pro Legacy Export issue ON DEADLINE! sound synch
  • Export issue ON DEADLINE! sound synch
    Posted by Zube on August 16, 2006 at 4:21 am
    I am usung FCP 3.0 to capture an entire mini-DV tape. This works fine, even with capture now.
    I am burning time code onto the screen with the TCG filter.
    When I export the file using photo-jpeg between low/mid quality it creates an hour long quicktime file but the sound loses synch about halfway through. Its SEVERAL seconds out of synch by the end of the movie file.
    Should I use something other than photo-jpeg to export?
    I need to keep the file size just under 8 gigs. Why is it going out of synch?
    I need to create DVD’s of the mini DV tapes with time code on the screen, and I have very little time left….
    Zube replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
