Activity Forums Adobe After Effects Export is forcing a resizing that I don’t want
  • Export is forcing a resizing that I don’t want
    Posted by Steve Newberry on August 28, 2012 at 2:30 am
    Getting this warning when trying to export with the MPEG4 codec (CS5.5):
    warning:output file will be resized from 1024 x 576 (1.00 PAR) to 720 x 576 (1.46 PAR) to meet format constraints… problem is the client needs it in this codec at that ratio and not resized!
    What’s going on here? Any way to work with this or around this?
    Gameli Cruz replied 8 years, 9 months ago 4 Members · 4 Replies
  • Keith Mcgregor
    August 28, 2012 at 4:22 pm
    Sure is, export lossless and transcode to mpeg 4 in an encoding package. Done!
    -Keith
  • Steve Newberry
    August 28, 2012 at 4:26 pm
    Thanks… I juuuust did this. To those following along: I exported lossless and transcoded to mpeg4 in Compressor. Adobe Media Encoder could not do it at a high enough resolution for some reason…
  • Ben Hartley
    February 1, 2013 at 10:35 am
    I have had this problem but my comps were all exporting absolutely fine and i must have pressed something and now it is exporting in the wrong ratio! How can I put it back to normal so i do not have to convert afterwards???
    If it looks good, look at it.
  • Gameli Cruz
    November 7, 2017 at 11:32 pm
    OMG, I have the exact same problem. I was exporting beautifully and then I don’t know what I hit accidentally, It messed up some settings, No forces my exports to a very small resolution, useless movies,
    Can some one help me to return my settings back to normal?
