Activity › Forums › Adobe Premiere Pro › Export HDV to DV
  • Export HDV to DV
    Posted by Mike Cohen on September 16, 2010 at 5:55 pm
    Given an HDV sequence (1440×1080) with HDV video (PAR 1.33)
    I want my final output to be DV AVI Widescreen. However this has a PAR of 1.2.
    Thus, a direct export from the HDV sequence yields a nice looking AVI with thin black lines on the right and left side.
    There is no way to adjust the dimensions of a DV AVI in media encoder.
    In other export formats I can adjust the dimensions to, say 705×480 which is the correct size for this export.
    Should I simply create a custom export setting?
    Changing the PAR in Premiere using “interpret footage” does not fix the issue, since I am still on a HDV sequence – thus i can change the PAR of the footage but not the sequence.
    Thanks for your help.
    Mike Cohen
    Ann Bens replied 16 years ago 2 Members · 1 Reply
  • Ann Bens
    September 16, 2010 at 9:41 pm
    The only way to ‘fix’ this is to crop off 13 pixel top and bottom in the export settings.
