Activity Forums Adobe Premiere Pro Export HD project to Tape with CS3
  • Export HD project to Tape with CS3
    Posted by Kyle Conner on February 13, 2009 at 6:34 pm
    I have a sequence shot on a Panasonic HVX200 at 720P24PN that I need to dump to mini-DV tape. Does anyone know how to do this? Under file-export, export to tape is not an option. I know I can export it to the P2 card, then dump it to tape, but I was wondering if there was a direct route to tape. I know I will lose quality, but the place I’m sending the files can’t accept the .mxf files. Any help would be appreciated.
    Kyle Conner replied 17 years, 6 months ago 2 Members · 2 Replies
  • Mike Cohen
    February 14, 2009 at 2:57 am
    I do not think you can go back to mini-DV as 24p HD. Mini DV will accept 720×480 or HDV. But P2 or any kind of 720p is not going to go to mini-DV without transcoding to HDV or DV.
    In CS4 you can copy and paste a HD timeline onto a SD timeline. In CS3 you will need to import your 720p project into a 16:9 SD project, scale the clips accordingly, render and export. Same goes for importing it into a HDV project.
    Mike Cohen
  • Kyle Conner
    February 16, 2009 at 2:42 pm
    I set it up to do it that way but the rendering was going to take almost twice as long as the footage was. I wound up dubbing the clips I needed back to the P2 card and used my camera to dub the footage to mini-DV. I know I lost quality, but it’s what my client wanted.
