Activity Forums Apple Final Cut Pro Legacy export full feature from finalcut pro
  • export full feature from finalcut pro
    Posted by Greg Bloomberg on March 28, 2012 at 12:34 am
    Hello, I am finalizing several clips at a time, for a feature film.
    I want to be sure I have chosen the right quality, size, formats etc for each quicktime movie. I intend to put each segment back into final cut to make the complete film, have to do this because of space issue.
    This is what I made so far, Dimensions 1280×720
    codecs integer ( little endian) H. 264
    Is this correct or should I have used something else?
    Greg
    Also, why does my external hardrive NOT except a quicktime movie and tells me it is not a movie file?
    Rafael Amador replied 14 years, 5 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 28, 2012 at 11:04 am
    Don’t use H264. Use Prores.
    If you have edited H264, change the sequence codec to prores and set render in YUV; 8b or high precision.
    rafael
    [Greg Bloomberg] “Also, why does my external hardrive NOT except a quicktime movie and tells me it is not a movie file?”
    How is your external HD formatted?
    rafael
    http://www.nagavideo.com
