Activity › Forums › Apple Final Cut Pro Legacy › Export from FCP to FLV within FCP – Have Flash 8 – No option?
Posted by Elijah Lynn on December 6, 2008 at 12:11 amI have FLash 8 and FCP 6.0.5. I do not see any option to export straight to *.flv?
Any suggestions on how to enable this?
Antoine Vuduc replied 16 years, 4 months ago 5 Members · 15 Replies -
Rafael Amador
December 6, 2008 at 2:52 amIn Main> Library> Quick Time you need to have a “FLV Component”.
Export to Flash shows as an option when exporting with QT Conversion from FC.
rafael -
Elijah Lynn
December 6, 2008 at 3:32 amHi,
Thanks for your reply. I just checked my Library/Quicktime folder and I see a FLV.component file listed. When I go to “export/using quicktime conversion” and then click options/settings/compression type I do not see anything listed for flv or flash nor anything under adobe or macromedia.
Any further thoughts?
Thank you for your time
Rafael Amador
December 6, 2008 at 3:51 am -
Elijah Lynn
December 6, 2008 at 6:12 amHey Rafael,
I think I have a different version of FCP than you.
I attached screenshots of all my menus.
https://www.getdropbox.com/gallery/26576/1/flv-fcp-issue-menu-item-missing?h=720451
David Bogie
December 6, 2008 at 4:31 pmInstead of clicking on options, you need to open the Quicktime dropdown menu to the left of the option button.
bogiesan
Elijah Lynn
December 8, 2008 at 6:11 pmThere is no FLV option in that dropdown menu. I added a 6th picture to the gallery in the link above to show.
Rafael Amador
December 12, 2008 at 3:28 pmHi Elijah
Sorry I’ve been with no Internet for a few days.
You should have the FLV option in the list of your last PNG.
Try to reinstall the Flash software.
Rafael -
Elijah Lynn
December 12, 2008 at 3:50 pmThanks for your continued discussion. I reinstalled it once. I will try to reinstall it again. Should I also see “PNG” in the list as well?
Elijah Lynn
December 12, 2008 at 4:06 pmHey Rafael,
I just checked out the video on your website! Very nice work buddy!
Rafael Amador
December 13, 2008 at 12:25 amHi Elijah,
PNG is one of the options when you choose “Movie to Image Sequence”.
Rafael
