Activity › Forums › Apple Final Cut Pro Legacy › Export from FCP for Use in Avid
  • Export from FCP for Use in Avid
    Posted by Tim Scarpino on July 21, 2009 at 5:45 pm
    Greetings all,
    We use Avid Media Composer (on approved PCs) in our shop, and recently received some HD material from a vendor that was exported out of FCP as uncompressed.
    We are not able to open these .mov files in QT, or import them into Avid MCA.
    After some investigation, it looks like there might be an export setting within FCP that would allow these files to be used on a PC.
    Can someone please verify if that’s the case with FCP, and what exactly that workflow might look like?
    Thanks for considering,
    Tim
    John Fishback replied 17 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    July 21, 2009 at 6:05 pm
    If you search the Cow for “Avid codecs” and you’ll find many posts with the answer to your question. After the Avid codecs are installed on the FCP system, it will be able to export files for use on Avids.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
