Activity Forums Adobe Premiere Pro Export frame in CS4
  • Export frame in CS4
    Posted by Amila Kumarasinghe on September 9, 2009 at 7:40 am
    Hellow sir; when we use Adobe Premiere CS3 it has an option
    File > Export > Frame …….. to export single still frame quickly.
    But in CS4 we cant render out 1 frame on one click. how can we render single frame in CS4? have any shortcut or anything like that?
    (we can expport single frame from adobe media encoder as the exprt format in JPG or TIFF or like something; It is a long way. but the Previous situations are very usefull for busy environments.)
    Pleeeeeeease help me. . . . . . ..
    Amila C.
    Amila Kumarasinghe replied 17 years ago 2 Members · 6 Replies
  • Vince Becquiot
    September 9, 2009 at 3:27 pm
    The latest update in CS4 uses the export settings window but does not go through AME.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Amila Kumarasinghe
    September 9, 2009 at 3:36 pm
    thank you sir for respond my post.
    but I haven’t understand your answer perfectly.
    i asked how can we export a single frame quickly in Adobe Premiere CS4?
    (so we can do it in Premiere CS3 from FILE >> EXPORT >> FRAME)
    Can you tel me how can we do it from CS4? because we haven’t any option to render single still frame. . . . ..
    please help me. . . .
    Amila C.
  • Vince Becquiot
    September 9, 2009 at 3:51 pm
    File > Export media.
    Change Format to Tiff. Make sure the settings are correct. The export is instantaneous from that point.
    You could argue that it’s an extra click, but the 1st version version of CS4 forced you to open AME after that wait and hit render, so that’s quite an improvement…
    Vince Becquiot
    Kaptis Studios
    September 9, 2009 at 4:26 pm
    thanx sir.
    but u told the newer update like that.
    i installed CS4.1 update.
    but it always do the same.
    open AME and we can Qued files and we must hit render. anything wrong with my product?
    Amila C.
  • Vince Becquiot
    September 9, 2009 at 4:49 pm
    So if you select Tiff, or Bitmap it opens the render queue?
    If you go to help > About Premiere Pro is it really 4.1.0
    You didn’t check export as a sequence right ?
    Have you restarted after the update?
    It should simply ask you for an export location and that’s it.
    Vince Becquiot
    Kaptis Studios
    September 9, 2009 at 5:11 pm
    yes sir; thats my mistake.
    so sorry. i t works well.
    thank you very much 4 help me. i ll contact you later if i want.
    thank you again sir. . .
    Amila C.
