Activity › Forums › Adobe After Effects › export flv
  • export flv
    Posted by Oliver Odermatt on February 5, 2009 at 8:46 am
    Hi all
    I did export my 18 seconds comp to flv. Here you can see the result:
    web427.login-1.loginserver.ch/fileadmin/shop/intro/tom_shopintro.flv
    My only problem is, that the size of this 18s movie is 2mb??
    I played with the export settings but didn’t get it any smaller.
    Isn’t it possible to get it to a size like 600kb in an acceptable quality?
    Thank you very much for your help!
    Oli
    Oliver Odermatt replied 17 years, 7 months ago 3 Members · 4 Replies
  • Jon Geddes
    February 5, 2009 at 6:29 pm
    Adobe apps only do single pass On2 vp6 flv encoding. This results in greatly increased file sizes (and reduced visual quality!) at the same bitrate settings as a 2-pass encoder . Play around with the bitrate settings, try and go as low as you can without effecting the quality too much.
    My 53 second Texture Packs promo video @ 386×216 30p is only 3.62MB . That was done with 112 kbps mp3 audio, and 420 kbps variable 2-pass encoding on the video.
    In After Effects, with 96 kbps audio (less than the other one!), and 420 kbps video single pass encoding, the same video was almost 8 MB. It helps to have a separate application for encoding (such as sorenson squeeze)
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Oliver Odermatt
    February 5, 2009 at 8:02 pm
    Hi Jon
    Thank you very much for your response.
    I think I gonna get that squeez application!
    Oli
  • Chris Wright
    February 5, 2009 at 9:09 pm
    the reason sorenson squeeze gets file sizes so small is not only 2 pass, but it can do a trick called interpolate half frame rate. It will encode video at half the framerate then encode a flag in flash to tell it to playback smooth with cpu added fake “tween” frames.
  • Oliver Odermatt
    February 18, 2009 at 9:45 am
    hi all
    I tried the sorenson squeeze but it didn’t convert my alpha channel, I always get a black background.
    First I tried to compress my flv-file to flv. Because it didn’t work, I wrote to the sorenson support. They told me to export the movie to mov with alpha channels, check the alphachannel checkbox in squeeze and then convert it to flv with alpha channels.
    I did this but I still got a black background in my flv file.
    So I did write again twice to the sorenson support but didn’t get an answer yet. So it seems that it didn’work with alpha channels?
    any suggestions?
    thank you!
