Activity Forums Apple Final Cut Pro Legacy Export files with alpha
  • Export files with alpha
    Posted by Richard Boghosian on January 31, 2007 at 6:10 pm
    Starting with DVCPROHD tape, (I have a Kona card) I would like to take the green screen shots and apply a chroma key (I have Boris BCC) so that the images are cleanly keyed over a blank (no) background and then export files – which will be used on a DV timeline at another facility – so that they have the images with the alpha channel to work with. Workflow process suggestions???
    Richard Boghosian
    Bogh AV Productions
    Aaron Williams replied 19 years, 7 months ago 3 Members · 2 Replies
  • Chris Borjis
    January 31, 2007 at 6:24 pm
    I’m not aware of any realtime codecs that support embedded alpha channels.
    What I would do is create the alpha channels through keying and export ONLY the black/white mattes as new videos to a realtime playback codec, then use them as track mattes.
  • Aaron Williams
    February 4, 2007 at 5:39 am
    you should be able to export as a quicktime movie with the codec set to “animation” and set the color depth to “millions of colors+” (the + stands for alpha channel). you’ll have to render, but alphas are preserved in the format.
