Activity Forums Apple Final Cut Pro Export FCPX file with roles including master audio mix
  • Export FCPX file with roles including master audio mix
    Posted by Henrik Helms on June 7, 2013 at 11:39 am
    Hi!
    Is it possible to export a project as roles also to include a master mix in the first two audio tracks of the multitrack file?
    Greetings
    Henrik Helms
    dBA MEDIA
    Jeremy Garchow replied 13 years, 3 months ago 3 Members · 2 Replies
  • Matt Trubac
    June 7, 2013 at 11:50 am
    Would it work to duplicate (copy and paste your audio clips?) and put the duplicates in a compound clip, and assign a role?
    Someone else might have a more elegant solution.
  • Jeremy Garchow
    June 7, 2013 at 2:28 pm
    Yes.
    You can add a channel, then select all the roles for that channel.
