Activity Forums Adobe Premiere Pro export error: Unknown error
  • export error: Unknown error
    Posted by Navarone on June 25, 2007 at 7:15 pm
    I have AP project that I can export as a QT movie only two work areas. I have 5 work areas that I need to export. I have tried to whittle down the causes, but I can’t seem to isolate why it is giving me an error.
    When I export the work area, it seems to render all the frames and I have watched this repeatedly to know that it gets all the way to the end of the last frame and pop! up comes the error message. I am not even sure what the problem is, so I need some advise on what to look for and possibly check.
    I am not using any compression. The video compression is set to none, the audio is the default setting. I’ll be happy to supply any info to futher diffuse this issue.
    What is man that you should be mindful of him?
    Tom Krauska replied 19 years, 2 months ago 3 Members · 3 Replies
  • Navarone
    June 25, 2007 at 8:57 pm
    I would like to add to this: Is ther a QT file size limitation for rendered movie file out of AP for PC?
  • Mike Velte
    June 26, 2007 at 11:03 am
    [Navarone] “Is ther a QT file size limitation for rendered movie file out of AP for PC?”
    The hard drive you are capturing to must be using the NTFS file system to exceed FAT 32’s 2 or 4 gig file size limit.
  • Tom Krauska
    June 26, 2007 at 1:01 pm
    I’ve had trouble with QuickTime Export also.
    I’d suggest – Export as as avi file and then use QuickTimePro to change the file to a QT format.
    Here’s also another note I wrote to myself.
    If you use a Green Screen key on some video and you want to keep the old
