Activity Forums Adobe Premiere Pro Export each angle of an edited multi-clip edit?
  • Export each angle of an edited multi-clip edit?
    Posted by Dan Coffey on July 26, 2012 at 12:56 pm
    Hi, I am transitioning to Premier 6 from FCP 7. I have a multi-clip edit that I am looking to export 3 versions from:
    1) an edited version (trimmed to cut out garbage) that switches angles
    2) the same edited version (trimmed) but export that version of only camera 1
    3) the same edited version (trimmed) but export that version of only camera 2
    the result will be 3 files of the same length, 1 is a polished cut, the other two are basically iso feeds of the polished video.
    In FCP 7, I was able to select all of the video in a given multi-clip edit, then right click, then change the active angle to camera 1 or two – this would give me the iso of each angle from the polished cut.
    In Premier, if I have more than one clip within a multi-clip selected, I have no option to switch angles.
    Anyone know how to achieve what I am trying to do? Thanks for your help!
    Dave Brandt replied 14 years, 1 month ago 2 Members · 1 Reply
  • Dave Brandt
    July 26, 2012 at 3:06 pm
    Why not select one clip that is switched to camera 1, alt drag to a new track and extend it front and back to the length of the show? Repeat for other camera.
    Hope that helps
    Dave
    https://www.solidmedia.ie
    Macbook Pro 17″ i7 2.2 8GB
    iMac i7 2.8 16GB
    FCP 7 FCPX Adobe CS 5.5
