Activity Forums DaVinci Resolve Export+ does not wrap LUT into tarball file
  • Export+ does not wrap LUT into tarball file
    Posted by Erik Greensmith on October 3, 2011 at 2:51 am
    I used Export+ from Resolve 8.1 and included a 3D LUT applied individually to each clip in all the separate timelines (right clicking on the base node and selecting from the LUT menu, all clips used the same LUT file). The “LUTs” tab was selected in the export+ dislog box, as was “Stills.” When I try to import+ the project, everything comes in fine except for the LUT. The stills all import fine. What gives? On my system the LUT I’m using is stored in the Arri folder in the DaVinci application support.
    Vivek Vedagiri replied 14 years, 11 months ago 3 Members · 2 Replies
  • Peter Chamberlain
    October 3, 2011 at 8:46 am
    Hi Erik, can you confirm this is on 8.0.1?
    Are you exporting from Mac and importing on Linux, or visa-versa?
    Or Mac to Mac?
    Peter
  • Vivek Vedagiri
    October 3, 2011 at 3:33 pm
    Hi Erik,
    A few things to note:
    1. The LUTs exported with the project are meant to handle project wide LUTs (specified on the config page). So currently, node based LUTs are not exported even if you select the LUTs option while exporting.
    2. If you need to use the LUT as an input LUT on all clips, instead of applying it on the first node of each clip, it will be simpler if you select the INPUT LUT on the LUT tab of the config page. This will apply it on each clip before any color correction from the node graph. This will also ensure that your exported project has the LUT file in it.
    If you need to selectively use LUTs on certain clips (by specifying it on the first node) and still wish to have the LUT exported along with the project, a work around would be to apply the INPUT LUT from the config page, save the project, export+ and then upon importing, go to the config page and turn off the input LUT.
    Vivek Vedagiri
    Blackmagic Design
