Activity › Forums › Maxon Cinema 4D › Export audio using Mograph Sound Effector
  • Export audio using Mograph Sound Effector
    Posted by Symonteve on August 17, 2007 at 12:59 am
    I am presently developing a project using sound effector, but I am rather new at mograph in cinema 4d…so I haven’t been able to find an option to render the video together with the audio. I am also trying to figure out how to use many cameras for the renders, since I’d like to have renders of many views programmed at once…
    Adam Trachtenberg replied 19 years, 1 month ago 3 Members · 3 Replies
  • Alejandro Torres
    August 17, 2007 at 9:03 pm
    You can’t export audio with C4D, you must use a compositing program such as after effects.
  • Symonteve
    August 17, 2007 at 11:47 pm
    Thank you so much for your reply…I’ll try that. How about setting up different cameras in one render only? Is that possible?
  • Adam Trachtenberg
    August 18, 2007 at 3:35 pm
    [symonteve] “Thank you so much for your reply…I’ll try that. How about setting up different cameras in one render only? Is that possible?”
    Sure, that’s easy. You would use the Stage Object.
