Activity Forums Apple Final Cut Pro Legacy Export audio problems – sounds drops in middle of EXPORT
  • Export audio problems – sounds drops in middle of EXPORT
    Posted by Dog Food on August 19, 2006 at 5:37 pm
    HI!
    I have expoted an 8 minute piece from FCP as a QUICTIME MOVIE. When I open this EXPORTED QT file in FCP or in iDVD the audio drops out completely at about 3 minutes and then comes back in at 5 minutes.
    I have exported dozens of shows from 1-120 minutes and I have never experienced this.
    any thoughts?
    thank you
    Annaël Beauchemin replied 20 years ago 4 Members · 6 Replies
  • Annaël Beauchemin
    August 19, 2006 at 6:04 pm
    Do an Audio Mixdown in “Squence” -> “Render Only” -> “Audio Mixdown”. Or do a “command-option-R”.
    This is a bug that pissed me off quite a few times already…
  • Jeremy Garchow
    August 19, 2006 at 8:15 pm
    Delete your audio render files, re-render, and try again.
    Jeremy
  • Thaxter Clavemarlton
    August 19, 2006 at 9:06 pm
    [JeremyG] “Delete your audio render files, re-render, and try again.
    The MIXDOWN basically performs the same end result of doing that.
    Its the closest thing to a “super-fix” that you can do to a “Sticky” and/or Skipping” timeline.
  • Jeremy Garchow
    August 19, 2006 at 10:50 pm
    Sorry, Thax, I disagree. Deleting render files is the only way to start with a clean slate. If you have copied and pasted other rendered audio from another timeline and FCp loses track of the render file, it sometimes replaces it with silence. Completely removing any left over render files is the only way I have fixed this. An audio mixdown will simply include the offending render file.
    Jeremy
    August 20, 2006 at 4:16 am
    Audio Mixdown is one of THE most overlooked… but most IMPORTANT functions
    in curing timeline stutters and pauses.
  • Annaël Beauchemin
    August 20, 2006 at 3:09 pm
    [Thax] “Audio Mixdown is one of THE most overlooked… but most IMPORTANT functions
    in curing timeline stutters and pauses.”
    I would turn that sentence into “Audio Mixdown is one of THE most overlooked… but most IMPORTANT functions
    in curing mind twisting, head banging bugs.”
    I would add that it is overlooked simply because it’s a non-sense having to mixdown to get rid of FCP bugs like that.
